Fuser exit jam.
  • allan
    RTFM!!
    • 5462
    Fuser exit jam.
    Hi
    I have a B423 with FS-527. if i remove the FS all is well. But with the FS installed the paper jams in the fuser exit. cant figure this one out swoped the exit unit and the horizontal transport. Any ideas.
    Whatever
  • eg101
    • Jan 2005
    • 131
    Re: Fuser exit jam.
    Did you record the model and S N in the copier?
    • allan
      RTFM!!
      • 5462
      Re: Fuser exit jam.
      I did not install it so i have no idea. funny it was like that from install. Why do you ask this?
      Its not needed?
      Whatever
        • 22997
        Re: Fuser exit jam.
        Are you sure it's plugged into the bridge unit?
        We had a customer that was constantly moving machines around. Their IT dept could disconnect the finisher and unplug it, but never could manage to remember to plug in the bridge. It gets it's power from the finisher, and without the power the bridge unit rollers don't turn. =^..^=
        • wseyller
          • Sep 2012
          • 1129
          Re: Fuser exit jam.
          I would reseat them anyway
          • allan
            RTFM!!
            • 5462
            Re: Fuser exit jam.
            Sorry guys false alarm. Looks like i nailed it on the previous call. I was almost sure the call for jams came back for the same problem as before turned out to be a broken drum gear this time, after market crap i have to work with.
            I fixed that problem by lowering the fusing temp by 5 deg. The paper curl cause the paper to get stuck in the transport unit. It only happened intermitantly so was not sure if it was gone or not. But user confirmed that the machine was ok after my visit.
            Does anybody know how to switch on spel check for Chrome as english is not my first tonge.
            Whatever
            • allan
              RTFM!!
              • 5462
              Re: Fuser exit jam.
              Dont mind me I will just keep on answering my self.
              3 funky bars top right corner > Settings > advanced setting > language input method > tick spell check box.
              I know now I miss spelled the words answering and language. Pity the grammar still sucks.
              Whatever
                • 22997
                Re: Fuser exit jam.
                Spell check clearly helps. If you're using a translation website or software, I've found that it helps to keep your sentences short. The translation may not be perfect, but most times the basic thought gets through. I tend to be a bit verbose, so the short sentences are very hard for me to do.
                • allan
                  RTFM!!
                  • 5462
                  Re: Fuser exit jam.
                  Hehe, my english is not that bad. I just really suck at spelling. Never know when to put in double letters like nn ll mm or I don't really care. Dont what to look like an idiot tho.
                  Whatever
