C353, Error: Service Call occurred. 45-52
  • jayg30
    • Jun 2014
    • 47
    A KM C353 is sending emails with the following.
    Doesn't seem to be happening in any pattern.
    Occurred Time :MM/DD/YYYY HH:MM:SS
    Installed Place:[location]
    IP Address :xxx.xxx.xxx.xxx
    Also...
    Error: Service Call occurred. 25-58
    Any idea what this could pertain to? Machine seems to be functioning fine.
  • CompyTech
    Super Tech
    • Feb 2011
    • 706
    Re: C353, Error: Service Call occurred. 45-52
    4552 is a PH unit failure, more specifically LASER M FAILURE. You'll need a new printhead, these units are prone to failure(design defect). The other code is a high TCR on K IU(imaging Unit). Take out the K IU and toner first, and give them a good shaking. But be prepared to replace the K IU. Also the laser unit is not easy to get to if you're a green tech or end user. Very expensive and time consuming.
    • jayg30
      • Jun 2014
      • 47
      Thanks. I have it under a service contract but have had issues with getting "correct" diagnosis from them in the past. Your info will help me in dealing with them. I gave the units a shake but will call the tech.
      • allan
        RTFM!!
        • 5462
        Be careful one dealer only tried to upgrade the machine and quoted them R84 000 i fix it for R 2500 and made money. Is the machine on lease? C200 Y laser.
        Whatever
