print stop
  • stedros
    • Oct 2011
    • 34
    [Dead] print stop
    Hello friends I have a machine bizhub c550 it is showing print stop when ever u try to send work on it how can I solve it because it is puzzling mi, thanks in advance
  • allan
    RTFM!!
    • 5462
    Re: print stop
    Do u need to put a code into the machine to access the functions?
    Whatever
    • copierwhisper
      • Mar 2013
      • 78
      Re: print stop
      I had a C353 that acted the same way because the image units had reached 150% of life. With the firmware and proper settings that allow the machine to run components past 100% is great, but in my case it caused the print stop situation...once I replaced the image units that were at 150% the machine ran great again. Good Luck!
      • allan
        RTFM!!
        • 5462
        Re: print stop
        The massage i was thinking of is "deleted due to error" not "print stop" sorry about that.
        Whatever
        • deepdiver
          • Dec 2013
          • 13
          Re: print stop
          Might be barking up the wrong tree here but I think you may have no stop firmware installed and 1 or more consumable items are way past life. However, you need to check the IU life stop setting in enhanced security mode and set it to no stop.
