how to set a software switch
  • bronco31
    • Aug 2009
    • 174
    KM Bulletin 7528 details how to turn off end of life Unit Life messages , fusers, belts and IUs
    special firmware then different TechRep Mode settings.. one of which details Software Switch settings in SW# 55 and 51..
    simply set the HEX value and press FIX...
    well it wont stick! the value i set will not stay! highlight HEX or the Sw# or the actual binary row.. no matter what the new values will not FIX...??
    i searchd the SM and cant find any clues as to maybe another SW switch that allows the settings to FIX?
    any KM techs seen/had this issue? thx for any help!
  • allan
    RTFM!!
    • 5462
    Re: how to set a software switch
    Model of machine? It would be a HEX value followed by a bit value then the bit state "0" or "1"
    Whatever
    • copier tech
      • 8164
      You need to update the firmware to enable you to set the "End life stop" settings etc
      • PeterG
        • Jul 2008
        • 177
        You are switching machine on/off after fix aren't you?
        • bronco31
          • Aug 2009
          • 174
          sorry.. u guys cant read my mnd??
          its a C353..
          yep upgraded firm to R6 per bulletin..
          hit FIX
          powered off powered on
          just will not stick.. the HEX value (which i understand is saved on the NVRAM) just will not change.. it returns to its previous value..
          i need this as its soon going to call for all the Color IUs !
          thx all..
          guy
          • copier tech
            • 8164
            When you enter the HEX values, say D0 for switch 51 I think, only enter D, if you try & enter D and the 0 for some reason it doesn't fix!
            • bronco31
              • Aug 2009
              • 174
              ok i'll try that.. but i remember also setting the binary switches which auto fills the HEX value.. and still didnt stick...value went back to what it was previously...
              when copiers misbehave!
              • copier tech
                • 8164
                This can also happen if you dont have the life stop fw installed
                • emujo
                  • Jun 2009
                  • 3009
                  Here's my stab at it....Your MFP is bellow the function version required to use the R6 firmware. Set softswitch 25 to a HEX 30 ( I believe this is ver 3), cycle power, you will probably get an E002 error code (normal), if so, perform the HDD version up in service mode/state confirmation/HDD version up. After the update, cycle power again and try to set your switches. Emujo
                  • bronco31
                    • Aug 2009
                    • 174
                    i will try dpsw 25 thx....i may hv the solution ...gonna try this solution i just now found from the troubleshooting PDFdpswitch.JPG...
                    thx... have a great weekend all...get outside, get some sun.. dont think about copiers!
                    • bronco31
                      • Aug 2009
                      • 174
                      although now that i look closely at this PDF solution...the wording for the steps to do is terrible...
                      sigh...
