C360 flips corner skews image
  • Mikl
    • Nov 2011
    • 15
    intermittently flips rear corner over to top running 11" lead edge. swapped fuser and transfer roller/assembly. skews image. tray 2 and LCC. Forget to try 1 was 8.5x11R and OK. TIA
  • BR549
    • 111
    Re: C360 flips corner skews image
    CAUSE: The registration rollers have a paper guide which can sometimes be a bit tight so that the sheet catches and becomes folded.
    SOLUTION: Ensure that the lift board of the PC-408 and the trays are correctly adjusted so that the stack is parallel with the bucket. If the problem persists, please use a bizhub C554 Cushion (p/n A161164902) to enlarge the space.
      • 23007
      That was my suggestion. =^..^=
      • allan
        RTFM!!
        • 5462
        Check the paper guides where the paper exits the tray. The tab on the on side brakes and the guide causes paper to screw.
        Whatever
