konica c363 color streaks on b/w copy
  • DOE
    • Mar 2010
    • 258
    have a customer with a konica c363 that black and white is set as priority. 4 times in 2 months they went to print out a black and white copy and it had red streaks down one side(looked like failed blade) and alternating yellow green and blue down the other side. it took 7 copies for it to clear up. this only happens once every couple weeks. any ideas thanks
    • 23009
    Re: konica c363 color streaks on b/w copy
    For starters I think you need to check the model number. Valid models include:
    bizhub C360
    bizhub C364
    bizhub C364e
    bizhub 364e
    bizhub 363
    but never bizhub C363. Since you so specifically describe color images when selecting monochrome, I think I can safely assume that it is a color copier. Most likely the primary transfer belt is not cleaning off the color registration patches completely. =^..^=
    • avio2
      • Jul 2010
      • 150
      probably blade tranfert belt
      if are c360
      form lumps toner in the downhill in recovery
      check if it is blocked
      • DOE
        • Mar 2010
        • 258
        bizhub C360
        bizhub C364
        bizhub C364e
        bizhub 364e
        bizhub 363
        konica c360
        • DOE
          • Mar 2010
          • 258
          have a customer with a konica c360 that black and white is set as priority. 4 times in 2 months they went to print out a black and white copy and it had red streaks down one side(looked like failed blade) and alternating yellow green and blue down the other side. it took 7 copies for it to clear up. this only happens once every couple weeks. any ideas thanks
          konica c360
            • 23009
            If you're getting multiple colors it's most likely the transfer belt cleaning blade that has failed. Perhaps there is a piece of paper shoved in there. Sometimes you can clean the blade and re-prime it. But 9 times out of 10 you'll have to order the primary transfer belt assembly.
            Are you getting the mustaches? That usually means their is one or more pierce hole(s) in the primary transfer belt. =^..^=
