c552 nic problem
  • wd40hoehandle
    • Jul 2025
    c552 nic problem
    Cannot get unit to communicate with network, no blinking lights on interface. On this model is there some type
    of security lock out that will not allow communication. My first time with this model the nic card is a bear to remove and
    install. Appreciate any suggestions and help
    wd40
  • allan
    RTFM!!
    • 5462
    Re: c552 nic problem
    Use your laptop and another flylead directly the cable or wallbox could be dead or not patched at all?
    7 -> Physical
    6 -> Data link
    Those to layers makes the link LED go on.
    Is TCP/IP switched on under administrator -> network.
    Still if the NIC gets power and another node the link LED would light up.
    Whatever
    • Synaux
      • Mar 2012
      • 1224
      wd40
      First, I would try to hook it up to a laptop with a crossover cable to eliminate any potential networking issues.
      If the NIC light is not lighting/blinking, I would suspect that either the port is damaged (perhaps an easy solder fix) or a board failure. The board is not too difficult to get to--its mostly just a bunch of
      worthless panels you need to remove.
      I am unsure if there is a NIC reset tool for the cxx2 series, but this sounds hardware related.
      • wd40hoehandle
        Is it possible to use a network to usb converter and basically do the same thing as a network port?
        Thanks wd40
        • Synaux
          • Mar 2012
          • 1224
          Thanks wd40
          I don't see why not (although I have never used one).
          I would invest a few dollars (or make one) for a crossover cable anyway--they can be invaluable at times.
          • wseyller
            • Sep 2012
            • 1129
            With a modern Microsoft OS on a laptop with a standard cat5 cable should allow the link lights to blink on the MFP. The Auto-MDIX technology in modern devices automatically senses the wires and configures the network interface card accordingly. If not try initialization, clear all data and try again. If still doesn't work the board may be bad.
            • allan
              RTFM!!
              • 5462
              Jip all new laptops for a while now will crossover by itself.
              Whatever
