bizhub c224e network
  • finni72
    • Jul 2010
    • 25
    Hi.
    Is there a way to reset the network card without entering the webbrowser or entering administration?
    The machine is a little fucked up. He cant find an ip adress and whwn entering administration the network setting dows not show up.
    The only error i get is "waiting for ARP-request"
    This happend after i turned of the auto ip in network settings.
  • mrwho
    Major Asshole!
    • 4299
    Re: bizhub c224e network
    Have you tried the proper 5801 reset for the ncs?
    Edit : ignore this. I was thinking of ricoh.
    Mascan42
    Ibid
    • wseyller
      • Sep 2012
      • 1129
      You just may need to give it more time but otherwise in service mode under initialization you can clear the network related portion.
      • sasa12u
        • Nov 2011
        • 39
        try to format the ssd.
        • finni72
          • Jul 2010
          • 25
          Thanx.
          I will try it tomorrow.
          • menosmola
            • Apr 2014
            • 95
            Originally posted by finni72
            Thanx.
            You solve this issue? if yes, How? same problem here...
            • copier tech
              • 8200
              Try updating the firmware & setting to function version 7 if not already.
              • Max
                • Oct 2011
                • 566
                You can reset network in service mode System 1, Initialization ,Network data
                • finni72
                  • Jul 2010
                  • 25
                  I fixed the problem by putting a switch between the bizhub and the server.
                  The strange thing was that I could not communicate with the server even though I had set static IP with the correct subnet mask and Gateway.
