BizHub 223 help
  • Elmo
    • Feb 2010
    • 541
    BizHub 223 help
    Hi Folks
    I have a 223 that i need to clear network settings on
    when in admin the network box does not appear but in the top of the screen
    it displays waiting for ARP request
    i presume it has been set up in the software switches
    i do not have a manual for this model can anyone point me at the correct
    switch number and value i need to clear this
    Thanks in advance
    I Used To Live To Fix Things Now i Fix Things To Live
  • meyu334
    • Aug 2012
    • 20
    Re: BizHub 223 help
    try to reset machine to factory deafauls, then try turn DHCP to on and check that machine get ip .. if not then manualy type.
    Firmware are latest?
    • CompyTech
      Super Tech
      • Feb 2011
      • 706
      Re: BizHub 223 help
      Go into service mode, system 1, initialization and there should be a network data clear.. That should blow out the network settings to factory default without wiping the whole machine.
      • Elmo
        • Feb 2010
        • 541
        Re: BizHub 223 help
        Initializing does not clear it
        it needs to be turned off in the software switches
        anyone help with the switch and bit number ?
        • Synaux
          • Mar 2012
          • 1223
          Re: BizHub 223 help
          I am pretty sure there is a NIC reset for this model that is typically bundled with the NVRAM recovery tool.
          This will cause the button to reappear in admin mode. I have had this happen a few times with other models.
          • Elmo
            • Feb 2010
            • 541
            Re: BizHub 223 help
            The machine had the hdd removed before we got it
            i installed a new one and formatted hdd and ssd
            then set machine back loaded animation data
            now all working ok
            • Synaux
              • Mar 2012
              • 1223
              Re: BizHub 223 help
              now all working ok
              Hooray! : )
              • allan
                RTFM!!
                • 5429
                Re: BizHub 223 help
                now all working ok
                SSD?
                Whatever
