Bizhub C452 Scanning Quality Issue
  • integritybob
    • Jul 2008
    • 67
    All scans show fine pink lines over entire image across scan direction (parallel with exposure lamp). Shows up in scans and copies, but print jobs are fine, indicating problem is in the scanner area. Doesn't matter if original is scanned using feeder or placing on glass. See image.
    I have never had a scanning issue like this before, so this had me scratching my head. I did the obvious old school stuff (clean mirrors, etc.) which had no effect.
    CCD? Any suggestions would be greatly appreciated.
    --Bob
  • allan
    RTFM!!
    • 5462
    Re: Bizhub C452 Scanning Quality Issue
    Is this a new install?
    Whatever
    • Synaux
      • Mar 2012
      • 1224
      Reseat your data ribbon cables, I would suspect the scanner relay board before the CCD--looks more like a data issue to me.
      • Synaux
        • Mar 2012
        • 1224
        Also, are there any codes??
        • integritybob
          • Jul 2008
          • 67
          No, the customer has had the unit for about a year with no problems, had not moved it or made any changes, and the scan issue was the reason for the service call.
          --Bob
          • integritybob
            • Jul 2008
            • 67
            No malfunction codes, no P codes, unit functions normally in every way except for the scan issue.
            --Bob
            • integritybob
              • Jul 2008
              • 67
              Thanks, I'll give the ribbon cables a shot before I start replacing boards.
              --Bob
                • 23003
                Perhaps the "Lines Of Shame"? =^..^=
                • emujo
                  • Jun 2009
                  • 3009
                  Not Lines of shame...looks like a filter problem in the CCD. This MFP has been around for some time, wouldn't surprise me to see boards going bad. Emujo
