Konica Minolta C253 Fax
  • mearmi
    • Oct 2010
    • 350
    [Misc] Konica Minolta C253 Fax
    Konica Minolta C253 cannot send fax.
    It shows transferring for long time (we waited for 25-30 minutes).
    then we we have to delete the job as client has copy and print jobs.
    please advise any default settings in service mode?
    Thanks and regards
    mearmi
  • copier tech
    • 8174
    Re: Konica Minolta C253 Fax
    Press hook, do you have a dial tone?
    • mearmi
      • Oct 2010
      • 350
      Thanks for your reply.
      yes there dial tone and we can hear fax tone from another end too. It scans and stay on transferring
      • wseyller
        • Sep 2012
        • 1129
        Try a new phone cord. One with only two wires. Also bypass the surge if it runs through it.
        Does it happens with certain numbers.
        Turn on the line monitor and listen. Do you get a recording or hear anything strange.
        Is this an analog line or running over fiber/voip
        Try turning off ECM
        Try lowering the baud rate.
        If no go initialize the fax in service mode.
        • mearmi
          • Oct 2010
          • 350
          Try turning off ECM
          Turned off ECM and lowered the baud rate.
          it is working fine.
          Thanks a lot
          Mearmi
            • 14813
            Is this a new fax install? Has it been working and the suddenly stopped?
            Check that the marketing area is set properly.
