Bizhub 3300P (Printer) Cassette Feed Trouble
  • leoace
    • Jan 2012
    • 12
    [Jamming] Bizhub 3300P (Printer) Cassette Feed Trouble
    Hi guys,
    we rescently experience a lot of problems with the Bizhub 3300P Printer in field service. I know that paper pickup system from lexmark (looks familiar to E460), but never had these problems in lexmark service.
    First i checked the motor and clutch mechanic, the Paper Pickup itself from cassette works fine, but about 50% of all machines can not pick up paper as soon as the cassette reach a low-fill limit (ca. 50 sheets).
    If you refill the cassette, the pickup mechanism seems to work again. I noticed that the Pickup Arm will be released by that small shaft on the left side as soon as the you put the cassette back into the machine. But on low paper, the arm pickrelease.jpg motors.jpg
    thanks guys
    PS: with low paper status, machine just keeps trying to feed paper and shows up the same error msg as if the cassette was empty
  • mo0651
    • 1054
    Re: Bizhub 3300P (Printer) Cassette Feed Trouble
    Clean the feed rollers with 409.... Finding oil on rollers from the factory.
    • leoace
      • Jan 2012
      • 12
      I just quote myself
      the arm , there are about 5mm blank space between pickup roller and paper sheets when the cassette is back in machine
      so i guess, its not a cleaning problem, besides that fact that even machines with only 1500 printes pages got that problem and the pick rollers are dust dry and clean. But thanks anyway
      • Taminol
        • 171
        Originally posted by leoace
        Hi guys,
        If you refill the cassette, the pickup mechanism seems to work again. I noticed that the Pickup Arm will be released by that small shaft on the left side as soon as the you put the cassette back into the machine. But on low paper, the arm , there are about 5mm blank space between pickup roller and paper sheets when the cassette is back in machine. I removed the upper spring from pickup arm as a test - even without the spring mechanism the pickup arm does not reach the paper sheets in the cassette with low paper filling........
        KM released3300P jams at take up.pdf a bulletin for this the other day, but it doesn't really fill me with hope though......
        • leoace
          • Jan 2012
          • 12
          Thank you. I already knew these "solutions". Have replaced the feed roll clutch already, sadly without success.
          Another solution here is a different type of pickup roll from a totally different machine. The pick up roll needs to be cut on the edges because its too wide/thick, but ive been told it should work with these "modified" rollers. will leave you all a info as soon as ive tested it !
          Originally posted by Taminol
          KM released[ATTACH]28241[/ATTACH] a bulletin for this the other day, but it doesn't really fill me with hope though......
          • leoace
            • Jan 2012
            • 12
            *** Update 16.04 //
            We now have slightly modified "white" pickup rollers. Additionally some machines seem to work better with a 5 or 10g wight, placed with some glue on top of the pickup arm. Both are no final solutions, but work for the moment
            • hotfuser
              • 180
              *** Update 16.04 //
              Did you say that you tried the modified feed roller?
              They seem to be working ok
              • allan
                RTFM!!
                • 5462
                I wonder why the paper tray needs to be changed every 200k? Separation problems?
                Whatever
                  • 23009
                  *** Update 16.04 //
                  Pictures, please! =^..^=
                  • wseyller
                    • Sep 2012
                    • 1129
                    Thanks for info. Will be on the lookout for this. Is this also an issue with 4000P and 4700P. We have mostly sold 4700P.
                    • allan
                      RTFM!!
                      • 5462
                      Both those machines (40/47) use lift plates and separation rollers, its a bit different to the 3300P.
                      Whatever
                      • leoace
                        • Jan 2012
                        • 12
                        **UPDATE II : we now have green-blue feed rolls as part of misfeed solution. We also noticed that the "clutch kit L/M" clutch/motor causes missfeeds or errors even on almost brand new machines. Have replaced a few clutches arleady after only 1 -3K pages
