J-1051 on start up followed by C-3102 lock up error code
  • cjrb
    • Jul 2025
    [Error Code] J-1051 on start up followed by C-3102 lock up error code
    Bizhub Pro 6501. Getting start up error code J-1051 and 10 seconds later C-3102 (lock up screen). Checked and replaced:
    1. Swapped fusing units. Still the same errors.
    2. Checked I/O state of PS26 (Paper feed sensor /BP) 19-03 shows 001 (that there is paper in there). Made sure nothing is blocking sensor. Still 001. Replaced the sensor. It still shows 001.
    Any ideas or suggestions?
    Thanks in advance
  • ChrissyG
    • Jan 2013
    • 30
    Re: J-1051 on start up followed by C-3102 lock up error code
    Im having the exact same problem, did you manage to fix this issue?
    • Nelo
      Thanks in advance
      Had asimilar problem and found a one-way gear is slipping in the fixing drive assembly.
      Try replacing the (3) fixing drive gears with the modified Fixing Drive Gear/M 22T and the fixing drive shaft.
      • ChrissyG
        • Jan 2013
        • 30
        I changed the Conveyance Drive board yesterday and now all working fine again, I realised if I had the ADU pulled out it would come up with error 3919 I think saying fuser not in correctly.
        • sonnyphoto
          Thanks in advance
          I'm having the same problem did you solve your problem yet? I just change the fuser and no change.
          • sonnyphoto
            Ok I change the conveyance board and now i'm back up and running.
