biz hub 282 screen stuck
  • digicor
    • Jul 2008
    • 1153
    I have a biz hub 282 and it will no go to ready, it just stays on the minolta screen, i have checke all the connections, un hooked the fax, re set the reset button on the main board, then i got to trouble reset and re set and cleared all info on all the prompts, still no results. is this the main board or epromm?
  • Nelo
    Re: biz hub 282 screen stuck
    Have you tried uploading new firmware? If not, then youhave to download a new firmware and try upgrading. If this doesnt work then you may have a hardware fault.
