Konica Minolta C541 Bad Printing Quality + C-2557 error
  • jack1985
    • Mar 2015
    • 5
    Hello guys i am new to the forum and i really need your help!
    I own a bookstore and i have on Xeror Pro 55 that works fine and two color copier Konica Minolta a) Bizhub C252 also works fine and b) Bizhub C451 that has many problems till now!
    Right now my biggest problem is the quality after 300.000 prints in total 220.000 Black and the rest color and with normaly maintanance i face those problems!
    I get erros C-2557 and lines on print brown green yellow and in general very bad quality in all colors!
    I attached two samples!
    Thanks in advance for the help!http://tinypic.com/r/w9gxmq/8 http://tinypic.com/r/2utkv85/8
  • Imsdal
    • Aug 2009
    • 111
    Re: Konica Minolta C541 Bad Printing Quality + C-2557 error
    Hello there
    I assume that a strange noise also come from the machine and if is so, the cleaning doesnt work so well.
    Give me your email and i can send you the bulletin
    Cheers
    Imsdal
    • minimerlin
      • 851
      You need to replace or get a Tech to replace the Transfer Belt unit and the Black Image unit!
      Please do not PM me without asking first.
      • allan
        RTFM!!
        • 5462
        Yea to start with. Optics needs to be cleaned and gradation needs to be done. Get a Tech to check it out.
        Whatever
        • jack1985
          • Mar 2015
          • 5
          Originally posted by Imsdal
          Hello there
          Cheers
          Imsdal
          Here is my email kontonatsis@gmail.com
          • Max
            • Oct 2011
            • 566
            Nothing a basic service and a few new parts cant fix.
            • Imsdal
              • Aug 2009
              • 111
              Hi
              I just send you an email..
              Cheers
              • jack1985
                • Mar 2015
                • 5
                Hello again!!!
                Now i am more confused than before, i dont know what is the faulty or wich part should i change in order to have normal printing again!
                Every part is expensive and i dont have the ability to change all of them if its not necessary!
                I took out the transfel belt and as i saw everything seems to work almost fine,the cleaning blade cleans the belt but i saw some more toner at the edges that it seems not normal!
                Ok now i will attach one video showing the start up of the machine and a strange noise (gears not fitting preperly) i think and some photos of the IU that shows the toner and some strange lines of different colors!
                Please HELPPPPPP!!!!!!!!!
                Video here : http://tinypic.com/r/2rf3ame/8
                • 907tec
                  • 434
                  Transfer belt cleaning assembly failing. Very common on this model family. Best practice is to replace the Toner Collection Assembly PN#A00J R710 00. Those multicolored streaks at the top and bottom of the prints are residual toner from the machine's calibration process. Patches of toner are transferred to the belt where the density/opacity is measured. Those patches should be cleaned from the belt surface before the print job begins, but the cleaner motor (and/or gearing) is failing to do so.
                  Usually, it is possible to just replace the gears in the cleaner assembly, clean out the transfer belt's waste toner collection box and cleaning blade, and then reassemble. But, if you are tearing into that area, I would suggest replacing the motor as well.
                  *Edit* - Definitely clean off your imaging units, as well. Carefully. And keep them covered up with several sheets of paper when removed from the machine. Judging by all that loose toner, I would say it's time to utilize the printhead cleaning wand hidden in tray 1, also.
                  • jack1985
                    • Mar 2015
                    • 5
                    Ok i actually manage to de-assembly the machine and i am in the section that the problem is!
                    I saw not normal waste toner everywhere inside on laser beams on gears boards and everywhere!
                    Ok what part should i change now and where is located in the machine?
                    I attach some more photos to help you!
                    • 907tec
                      • 434
                      Cleaner gear assembly highlighted in red. You have to remove the motor from the back of the machine, though. IIRC, you have to remove the DC power supply to get access to the motor.
                      • habik
                        • 2013
                        Originally posted by 907tec
                        [ATTACH=CONFIG]28423[/ATTACH]
                        Correct!
                        Just the DC PWR SUPPLY isn't needed to be taken out!
                        Just ensure you have long Philips screwdriver!
                        IIRC main boards assy swiwels on a hinge, then HV BOARD to take out and then something awkward to take out to gain sort of access to the cleaning motor and gears. Be Aware That Those Gears have been MODIFIED!!! Get the new version!!
                        Good luck.
                        Sent from my iDon't believe in marketing device using Tapatalk
                        Firmwares HERE
                        • jack1985
                          • Mar 2015
                          • 5
                          so should I remove the motor and replace it with a new one???
                          • habik
                            • 2013
                            Usually just the gears!
                            When youbreak a tooth do they fix the tooth or change the whole mouth? Take it out examine the gears and motor spindle and you'll see whats going on.
                            Firmwares HERE
                            • Albonline
                              • Sep 2008
                              • 1153
                              Golly, just call a tech.
