Bizhub C754e crumpling paper through the ADF
  • garyaird
    I have a peculiar issue with a bizhub c754e, basically what happens is if you try and use the document feeder to make a copy it will pull the paper through and crumple/wrinkle it, and the original comes out looking like a dogs dinner.
    Has anyone experienced this issue? the document feeder is standard equipment on these machines.
    Cheers
    • 23009
    Re: Bizhub C754e crumpling paper through the ADF
    You might remove any foreign objects like paper clips, staples, insects, etc. =^..^=
    • habik
      • 2013
      Jam code?
      Any pics of the original? Before and after.
      Any particular type of paper?
      Sent from my iDon't believe in marketing device using Tapatalk
      Firmwares HERE
      • habik
        • 2013
        Is the brush turning in the ADF ? Actually do both turn nicely?
        Firmwares HERE
        • wseyller
          • Sep 2012
          • 1129
          I would be nice to know how far the paper get before it crashes. Jam code will give an indication of what sensor is involved which gives an idea of location.
