BIZ HUB 951
  • antone
    • Oct 2014
    • 344
    BIZ HUB 951
    For some reason copies get light fill.Even after a PM...a short time later copies get light.Density doesn't stay at this print shop!!![emoji20]
    • 23010
    Re: BIZ HUB 951
    What parts did you replace on your PM? Which PM? What simulations did you do? =^..^=
    • antone
      • Oct 2014
      • 344
      Re: BIZ HUB 951
      Replaced drum an developer.. 750k density just doesn't stay!
        • 23010
        Re: BIZ HUB 951
        You really ought to change the change at least the corona wires, grid, wire cleaners, drum blades, and do the drum peculiarity adjustments. I would not call drum and developer a complete PM by any stretch of the imagination. You might glance at the PM recommendations in the manual. =^..^=
        • antone
          • Oct 2014
          • 344
          Re: BIZ HUB 951
          750 pm kit contains all these parts!!!
          • JR2ALTA
            • Feb 2010
            • 2033
            Re: BIZ HUB 951
            did you do the peculiarity like he said?
            also fuser pressure?
            does the quality last at least for while? you may have toner add problems
            • Zackuth
              • Aug 2009
              • 448
              Re: BIZ HUB 951
              You have to run the peculiarity according to the manual. If you miss a certain step, the copies will be light and you'll have to replace the developer again. I don't remember which step, but I missed it on my first PM for these machines.
              If at first you don't succeed, redefine success
                • 23010
                Re: BIZ HUB 951
                Then perhaps you should install the kit. The way I'm reading your first post, you have "Replaced drum an developer.," Spare me the temper tantrums, please. =^..^=
