J20-02 C364
  • allan
    RTFM!!
    • 5462
    J20-02 C364
    Hi here is another way to fix the J20-02 problem, just glue plastic cutout (1mm thick) the the body where the hooks must catch only bottom 2 of the 3 door hooks.
    Allan
    Whatever
  • Issac-brock
    • Jan 2015
    • 61
    Re: J20-02 C364
    look on the left in the middel [ATTACH=CONFIG]28445[/ATTACH]
    Allan
    That's a good idea. I have the new modified springs for the idle rollers on the door, gonna try them on the next j20-02 call I encounter.
    • allan
      RTFM!!
      • 5462
      Re: J20-02 C364
      Do you have a part number for that springs?
      Whatever
      • HoonBoy
        • May 2011
        • 130
        Re: J20-02 C364
        Also tried your solution in the past, also worked in some cases...
        check this post as well, for springs:
        http://www.copytechnet.com/forums/ko...e-20-02-a.html
        • tech51
          • 846
          Re: J20-02 C364
          Have you tried fitting the modified (ribbed) conveyance roller that fits in the e versions?
          I've fit these a lot on the e models and it works fine.
          I'm guessing it will fit as the feed unit is the same. May be worth a try.
            • 23008
            Re: J20-02 C364
            I'm not seeing it allan. Is there another photo? =^..^=
            • allan
              RTFM!!
              • 5462
              Re: J20-02 C364
              This it the real fix.
              Whatever
              • allan
                RTFM!!
                • 5462
                Re: J20-02 C364
                Sorry don't have any other pics. Its difficult to see the plastic pieces is the same color.
                i just pulls in the door by about 1mm on the front side putting more pressure on the rollers.
                Whatever
