konica minolta 7272
  • cypcopier
    • Dec 2008
    • 17
    konica minolta 7272
    Hi ,
    1 have a Konica Minolta 7272 and at display 'please wait for a while' and its not working. does anybody help me please .
    regards
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    Re: konica minolta 7272
    There are just too many things on that machine that can cause a "Please Wait" message. More info is required.
    What have you done so far?
    Do the fuser lamps cycle on and off?
    Does the finisher initialize?
    Do all trays lift into position?
    Have you cleared Memory and HDD?
    If left long enough does it eventually come up with an error code?
    Ok with absolutely no information here is my guess:
    1. Dirty sensors on toner control board or bad board.
    2. Bad interlock either front door, fuser latch, or ADU latch take your pick or check them all
    3. Scanner control board
    4. Bad memory
    5. Bad HDD
    6. And just for good measure everybody's favorite "Firmware".
    7. Time to upgrade.
    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
    Now into Ip TV KODI Boxes
      • 23007
      Did you please wait for a while? =^..^=
        • 14716
        Have you checked to see if the toner bottle is empty?
        • rbazan
          • Dec 2013
          • 70
          Description
          PLEASE WAIT OPERATING message is continually displayed at power up.
          Solution
          CAUSE: Failed Scanner Driver Board Assembly.
          SOLUTION: Replace the Scanner Driver Board Assembly (p/n 56AA-9091).
