C253 Operational Question
  • Solotime
    • 223
    On a service call yesterday and the customer asked me why their C253 with 519 Finisher will not offset stack when printing from the computer. It seems to work on single sided but does not offset stack when printing 2 sided sets. It will do it when copying 2 sided just not when printing from the PC. Any ideas?
  • copytechman
    • Nov 2008
    • 966
    Re: C253 Operational Question
    If you've installed the correct driver there should be an offset checkbox under the basic tab. it may not be checked by default.
    Regards!
    A.
    • Solotime
      • 223
      [QUOTE=copytechman;463154]If you've installed the correct driver there should be an offset checkbox under the basic tab. it may not be checked by default.
      Regards!
      Yes that box is checked. Driver is current PCL driver from KM
      • copytechman
        • Nov 2008
        • 966
        Is machine and finisher firmware up to date?
        Regards!
        A.
        • Solotime
          • 223
          Not sure on the firmware level but their C552 with a booklet finisher does the same thing....
          • copytechman
            • Nov 2008
            • 966
            Thats.. odd.... driver is supposed to override anything else.... how are the multiple jobs sent? If using word, don't use words collate function. Use the drivers especially when printing multiple sets... Using words collate function can cause weird issues with multicopy sets... I believe there is an offset each job setting @ the control panel too if I remember right... I may be mistaken tho.
            Regards!
            A.
            • Solotime
              • 223
              They are printing from Word and Publisher. Both programs do the same thing. Looking into the offset each job setting....
              • allan
                RTFM!!
                • 5462
                Go in on PSWC and check your printer settings there. Had problems with drivers not doing what they should when its set to double sided there.
                Whatever
                • JR2ALTA
                  • Feb 2010
                  • 2033
                  Word and Publisher have their own 'Page Setup' boxes that override (screw up) everything.
                  • JasonSBE
                    • Apr 2014
                    • 187
                    • habik
                      • 2013
                      As suggested above, uncheck the collate box in MS printer dialog.
                      Sent from my iDon't believe in marketing device using Tapatalk
                      Firmwares HERE
                      • Victor285
                        • Jul 2010
                        • 61
                        Sounds like the options aren't configured properly in the PCL driver. You might want to check in properties window of the driver, go to configure tab and see if the duplex and correct finisher are checked. Apply and OK out of configure tab & properties window. Then If you go back into printing preferences, see if you can select the features. If they are greyed out, you probably do not have the device configured properly.
                        Good Luck,
                        Vic
