C452 with solid black background
  • rindraintsoa
    • Sep 2010
    • 55
    hello all,
    I have a problem with my C452, there is a solid black background in every copy/print as you can see in the sample,
    I have put the drum unit on another C452 and the print is good (no background) so I thinked it was the developing Unit, replacing the developing unit with a new one the problem persists (black background) I took care about the poisitioning of the drum but the problem persists. Anyone have an idea about this problem?
    Thank you very much in advance.
  • wseyller
    • Sep 2012
    • 1129
    Re: C452 with solid black background
    Do you see this on the drum itself? If so block the laser and then if you still see it then likely a bad contact to high voltage or the HV board itself.
      • 23010
      Yeah, I was leaning towards primary charge contacts also. Notice that there is no void on the front or rear. Those voids will be lost is primary charge is weak/lost. =^..^=
      • wseyller
        • Sep 2012
        • 1129
        And I just threw in covering the print heads for the hell of it. Because if it is known for sure the combination of the drum and developer is doing that by itself without interference from the lasers, and it is known the drum/Dev unit are good then high voltage is the only thing I can imagine. And it looks like charge on drum is bad too me.
        • allan
          RTFM!!
          • 5462
          Yea im with BC on this does not seem to charge up the inconsistent lines is a give away. Just do a half tone at "0" to test for bias problems.
          Whatever
          • allan
            RTFM!!
            • 5462
            Thinking like my hind side halftone print would just do the same.
            Whatever
            • rindraintsoa
              • Sep 2010
              • 55
              if the printout with halftone is the same what to check in this case? Suppose the HV unit?
              • allan
                RTFM!!
                • 5462
                No follow BC's advice and check the charge connections. You can even replace the IU to test. There is problems with the way the IU k mounts there is a fix out on that. A while back one of our techs just reseated a unit to fix black prints.
                Whatever
                • carra
                  • Dec 2011
                  • 3
                  HOW I RESET K UNIT?
                  • carra
                    • Dec 2011
                    • 3
                    anyone fix this problem?
                    • joelea
                      • Feb 2012
                      • 64
                      Hi did you ever fix your original with the background, we are having a similar problem with a c452.
                      • carra
                        • Dec 2011
                        • 3
                        fixed that just reconecting laser flat cable on left side on machine.
                        • filladefilla
                          • Apr 2024
                          • 46
                          I have similar issue on KM c454e but mine comes with black backround with I print on heavy papers i.e. 200 - 260 grams. Pls, help.
