Networking problem
  • janinaresh
    • Jan 2013
    • 18
    Networking problem
    I have KM BH C451 and setup to print. I failed to make it print. The NIC is set to 192.168.0.11 according to the server TCP/IP protocol. Subnet and gateway are set to 255.255.255.0 and 192.168.0.1 respectively. When I ping through a CMD prompt it times out . I checked all cables and tried a known good cable from a known good hub. It failed again. The lights are off the connection at the copier. All cables are connected properly and screwed down tight.
    Is there a setting or switch I have to turn on? Is there a firmware available? Somebody could send to me?
    Thanks in advance for any and all help.
  • wseyller
    • Sep 2012
    • 1129
    Re: Networking problem
    If your not getting link lights its either the MFP board or more likely an issue with wiring switch etc.
    Hook a laptop up to it directly with cat 5 and see if you get link lights. I put money on it that you do.
    • janinaresh
      • Jan 2013
      • 18
      I attached laptop with machine, but not ping with cross cable, please
      • RRodgers
        • Jun 2009
        • 1947
        I'm pretty sure you can turn networking on and off on that machine. Are your sure it's turned on?
        • wseyller
          • Sep 2012
          • 1129
          Do you at least get link lights on the copier where the cat5 plugs into.
          You may have to configure your laptop to the same subnet to get a good ping. Set the ipv4 settings on your laptop to an IP address such as 192.168.0.50 and subnet mask to 255.255.255.0 and try again in a few seconds.
          • janinaresh
            • Jan 2013
            • 18
            When I started machine (KM BH C451) lan card light were blinking and then after never blinking lan card light.,
            • janinaresh
              • Jan 2013
              • 18
              I don't know how to turn networking on and off of the machine, please tell me the same
              • Albonline
                • Sep 2008
                • 1151
                buy the manual. you can get it from members here.
                • RRodgers
                  • Jun 2009
                  • 1947
                  The manual he needs is free from Konica, just go download it.
