Konica MINOLTA bizhub c35 - scanner lock error
  • teridar
    • Mar 2015
    • 6
    [Misc] Konica MINOLTA bizhub c35 - scanner lock error
    Hi, I have a problem with the KONICA MINOLTA bizhub c35, at this time the counter approaching 50 thousand. After switching on the screen copier is prompted to unlock the scanner. Needless to say that the mechanical lock the scanner is set to unlock. After turning the scanner lamp is lit all the time, regardless of the position of the ADF and the scanner does not perform any movement. Even as it manually before switching copier I move out of range of the sensor home. Any ideas? Already checked the continuity of the wires connected to the scanner and the continuity of the beam connecting the the document feeder
  • allan
    RTFM!!
    • 5462
    Re: Konica MINOLTA bizhub c35 - scanner lock error
    I had one that snapped the static drive belt and did the same. Also on a very low count but old.
    Whatever
    • teridar
      • Mar 2015
      • 6
      • allan
        RTFM!!
        • 5462
        the link is busted
        Whatever
        • teridar
          • Mar 2015
          • 6
          • Andrii
            • Mar 2015
            • 5
            If a firmware update will not solve the problem, check for fracture flat cables inside scanner module near scan head..
            • JasonSBE
              • Apr 2014
              • 183
              Fwiw I had that issue and after flashing the firmware, changing the ribbon cable, and changing the scanner I had to replace the mfp board to resolve it. Hope that's not the case with yours.
              • teridar
                • Mar 2015
                • 6
                Is there a newer firmware from that which I have (for central Europe)? bizhub_C35_ContFW_30G0112205.
                If so, does anyone could share?
                • teridar
                  • Mar 2015
                  • 6
                  In the service menu in the scanner sensor check list, FB scanner sensor always shows OFF, regardless of the position of the scanner. After uploading the firmware which has the fault is still the same.
                  • trscolin
                    • Aug 2012
                    • 21
                    We had this issue a while ago on a C35 and the FW did not help. We ended up replacing the entire scanner assy.
                    • Northwestservice
                      • Jan 2011
                      • 140
                      i have a few of these and have been told to keep a spare scanner assembly on hand because it will need replaceing at some time before 50k
                      • allan
                        RTFM!!
                        • 5462
                        Man i need to know how to prevent this i have one busted and 3 more on about 50K.
                        Whatever
                        • TTL
                          • Dec 2008
                          • 127
                          I'm with the same problem, the flat cable seems to be ok, the light is on, but the carriage don't move and it says to check the scanner lock - error.
                          • splblazer91
                            • Jul 2014
                            • 204
                            its usually just the scanner belt that breaks. 10 minute fix.
                            • Northwestservice
                              • Jan 2011
                              • 140
                              just found firmware for this issue
