Bizhub 36 Open and Close ADF message
  • captain
    • Mar 2015
    • 11
    Upon inspection it appears that the separation roller assembly is not lifting after feeding the paper through. It seems to try and pick up the assembly but it never makes it into the locking position. What could be the cause of this?
  • allan
    RTFM!!
    • 5462
    Re: Bizhub 36 Open and Close ADF message
    Its a bad ratchet. Replace the feed wheel assy. In between the rollers there is a slip clutch and on the end of that there is a badly designed ratchet that is supposed to give enough torque to get the roller assy to hook.
    The symptoms is a clicking noise.
    If you leave it long enough you will get a message that says ADF initialization error or something like that.
    Whatever
    • captain
      • Mar 2015
      • 11
      Thank you for the quick reply. I assume this is a common problem with the ADF on bizhub 36's considering I have had a number of them do the same thing.
      • allan
        RTFM!!
        • 5462
        Yea, but the replacements seems ok. Did not get that problem for a while now.
        Have to mention BH36=POS
        Whatever
        • giddyupngo
          • Oct 2014
          • 109
          I know this is an older post, but just ran into this same problem on a C35 last week. It was regularly displaying the "ADF Initialization Error". Konica Minolta recommended replacing the ADF, but just replacing the feed assembly worked. Fortunately it just clips in, no screws at all. We thought it was a loose ribbon cable at first.
          Thanks again and God Bless.
          • Imsdal
            • Aug 2009
            • 111
            • srvctec
              Former KM Senior Tech
              • Oct 2009
              • 827
              Had to revive this thread since I've had this issue on a bh36 for a couple years now, intermittently, so I could say a huge THANK YOU to your post, allan. Replaced the entire feed section (from a donor machine), problem came back. Replaced the entire ADF from another donor machine, problem came back. After seeing this thread and observing how poorly designed the slip clutch is on the feed assembly, decided to replace the whole thing since the rollers were worn pretty bad. Problem solved!
              Now that I know what the issue is, I have a solution that doesn't require replacing the super expensive feed roller assy. I just take out the cheap little slip clutch and put a couple rounds of tape around the clutch where the 4 plastic parts are supposed to expand and slip over the 4 corners of the inner part of the clutch. This tightens it up considerably, almost identical to the tension of a brand new feed assy. The mod only takes a minute or two and solves the issue as well. Hate how cheaply this little "clutch" is made!!
              Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
              • allan
                RTFM!!
                • 5462
                Made a mod too where i cut a groove and clip a single winding of a spring over it. There is a tread out there where i explained it in detail.
                But my solution was to replace every last B42/B36 machine with ex contract B363 machines because of the endless scanner belt, scanner cable, SSD , ADF and firmware issues they gave.
                Not sure think BC mentioned fixing it with a single cable tie.
                Whatever
                • allan
                  RTFM!!
                  • 5462
                  Forgot to mention. Your welcome.
                  Whatever
                    • 22990
                    I have a very vague recollection of something like that. I'm glad you have a good memory. =^..^=
                    • allan
                      RTFM!!
                      • 5462
                      Not sure and to lazy to find the thread...
                      Whatever
                      • Hansoon
                        • Sep 2007
                        • 3363
                        That's the problem with smokers kicking off. They become lazy.... lol
                        Hans
                        โ€œ Sent from my Intel 80286 using MS-DOS 2.0 โ€œ
                        https://www.copytechnet.com/images/smilies/biggrin.png
                        • allan
                          RTFM!!
                          • 5462
                          Hans
                          True story...
                          Whatever
