C224E Waste Toner Near Full Message
  • Mooseface2r
    • Jan 2011
    • 114
    [Misc] C224E Waste Toner Near Full Message
    Does anyone know what settings have to be made to make the machine warn that the waste toner is near full?
    I have tried lots of settings but none of them bring the message up
    Thanks in advance.
  • hotfuser
    • 180
    Re: C224E Waste Toner Near Full Message
    Thanks in advance.
    "near full waste toner " should flash up on 38,000 copies and 2000 later "waste toner box full message shows
    Check out pages O-75 in Therory of operation as this may explain it a bit better for you.
    I hope this helps
    • copier tech
      • 8169
      In SE mode, system 2 I think you have the comsumable near end warning yes/no
      • Mooseface2r
        • Jan 2011
        • 114
        Thanks for the responses.
        consumable near life is set to yes.
        This is what it reads in the manual, it basically says when the waste toner falls into the sensor on the waste box, the machine should then come up with a message to say waste toner near full.
        i am yet to see a machine give the message near full, they only ever say full and the machine be out of action.
        • pepper38_cnd
          Field Service Manager
          • Aug 2005
          • 1075
          The soft warnings on that machine are hid behind a yellow question mark in the upper right corner of the control panel. If you don't touch the yellow ! you don't see the message and most people don't. they may be displayed on the screen for a brief period before being hid behind the ! but if your not right in front of the machine at that time you missed it.
          Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
          Now into Ip TV KODI Boxes
