intermittent c0211 code on konica-minolta c280
  • imihm
    • Feb 2014
    • 77
    Hello there.
    We are having c0211 when printing from bypass.....just replaced the clutch and cleaned the sensor.....but no response,,,any ideas......????
    Thanks a lot
  • allan
    RTFM!!
    • 5459
    Re: intermittent c0211 code on konica-minolta c280
    Are you sure its C-0211 and not C-C211.
    Just asking because i had this code in this week ii mistook it for a C-0211.
    If its the bypass tray lift sensor if would let the lift tray go up and down before it errors out. Or make noise if its mechanical.
    look to see if something is not bent and that all the connectors ad wiring is OK.
    Whatever
