Bizhub 250 keeps running, won't print or copy
  • copyaction
    • Oct 2007
    • 991
    Customer called for me to look at this, i normally do Ricoh and Kyocera.
    She says it just keeps running but won't print or copy, but will receive faxes.
    I asked her if it needs toner but she said she just installed a new toner, and there is no message on the display.
    Anything common on these for this symptom, sounds to me like it is trying to add toner.
    • 23010
    Re: Bizhub 250 keeps running, won't print or copy
    Originally posted by copyaction
    ... sounds to me like it is trying to add toner.
    I'd have to agree. By the time you arrive there will be a toner indication on the screen ... or a C2557. =^..^=
    • allan
      RTFM!!
      • 5462
      There was a common problem with the bottle rotation gear train where one of the metal shaft pins would bend or tear out of the sheet metal. The machine would continuously with out stop try to add toner with no error or indication.
      Whatever
      • copyaction
        • Oct 2007
        • 991
        Was there a fix for that?
        • copyaction
          • Oct 2007
          • 991
          yes it now is asking for toner.
          so is it the motor, gear or whole assy that goes bad?
          • allan
            RTFM!!
            • 5462
            Strip and find the problem. The problem i am describing makes a ticking noise as the gear slips.
            Whatever
            • copyaction
              • Oct 2007
              • 991
              Yes exactly makes ticking noise and just keeps running
              • allan
                RTFM!!
                • 5462
                Strip it out to toner supply drive, you will see see the skewed gear you need to replace the bracket or TIC weld the shaft back on there.
                Whatever
                • copyaction
                  • Oct 2007
                  • 991
                  Thanks, is that bracket part of the toner supply drive unit, pn 4040076800
                  • wseyller
                    • Sep 2012
                    • 1129
                    This would be the entire assembly. If you order this it should take care of your problem. I have changed many of these but the first time is a bitch. You have to in addition remove some screws from the back to get it off.
                      • 15017
                      Replace the whole unit, it costs a bit more but it saves the aggravation of disassembling the drive assembly.
                      • copyaction
                        • Oct 2007
                        • 991
                        Thanks, I ordered the whole unit.
                        • copyaction
                          • Oct 2007
                          • 991
                          So I replaced this nightmare of a part, fired it up, no more clicking, went into add toner mode and then C2557.
                          Was unable to clear the code, does it now need a developer and drum replacement?
                          • allan
                            RTFM!!
                            • 5462
                            Tweak fix!
                            Open the developer tank and add a spoon full of toner.
                            Clear supplies life for the PCU. Restart the machine with the side door open start F8 and close the door.
                            Sometimes the new gain adjustment will stick.
                            If the prints are light repeat the process with another spoon full of toner.
                            Leave the cover off so you can see the toner bottle, run sky shots to see if the bottle turns.
                            If the bottle turn and c2557 or 2558 returns change the developer.
                            Whatever
                            • allan
                              RTFM!!
                              • 5462
                              Make sure every thing is plugged back in.
                              Whatever
