c452 with shadow background
  • juve
    • Dec 2012
    • 86
    [ATTACH]28827[/ATTACH][ATTACH]28827[/ATTACH][ATTACH]28827[/ATTACH]
    can someone give me an idea of what sort of problem I have in this c452 please?it is producing a shodow background as it can be seen in photo.any ideas.
  • Max
    • Oct 2011
    • 555
    Re: c452 with shadow background
    Maybe its my laptop screen but I cant see any shadows. What have u tried so far ?
    • juve
      • Dec 2012
      • 86
      see this one if it is better?
      • juve
        • Dec 2012
        • 86
        we swapped transfer roller,than we swapped laser unit(because there were lines,know lines ok),refreshed firmware,checked all connections which have to do with charging,but the shadow effect remained.
        • allan
          RTFM!!
          • 5462
          Check to see if the patern looks digital.
          Check your TCR level.
          Check for P-codes.
          Change IU.
          Whatever
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            stupid question, but initialized and done a gradation adjust ?
            • copier tech
              • 8136
              Yeah I would ask the same & what are your image unit lifes on? & using OEM toner?
              • juve
                • Dec 2012
                • 86
                yes we made initialisation and gradiation.everything remains the same.regards lifetimes,i will check,but surely I will try to replace I/U's and transfer belt.there are no p codes.tcr level ok.dev unit black is not arcing,no dev spill.
                • Max
                  • Oct 2011
                  • 555
                  Went to a customer on Friday and they also had some background on the copy. Not as bad as yours but still visible. They are not using oem toner though. I got some proper stuff coming in on Wednesday, will let you know what happens.
                  • juve
                    • Dec 2012
                    • 86
                    Originally posted by max
                    went to a customer on friday and they also had some background on the copy. Not as bad as yours but still visible. They are not using oem toner though. I got some proper stuff coming in on wednesday, will let you know what happens.
                    it seems that problem is solved after replacing c/m/y imaging units.seems ok!
