a line produced when making a copy on glass 454e !
  • jakani
    • Dec 2014
    • 147
    hi all
    when client make copy on the adf it goes normal buy when making it on the glass it produce a weird line on top , i checked the glass nothing on it it's clean !
    have anyone ever experienced this problem , what could be causing it ?
    any suggestion would be appreciated
    here is a sample :Scan1.PDF
  • minimerlin
    • 851
    Re: a line produced when making a copy on glass 454e !
    Originally posted by jakani
    hi all
    here is a sample :[ATTACH]28880[/ATTACH]
    Which is the feed direction? Have you checked and cleaned the optics path?
    Please do not PM me without asking first.
      • 23010
      The fact that the line tapers leads me to believe that it's primary charge related. Charge related lines can vary in thickness, whereas optics related lines tend to stay the exact same thickness.
      If you still think it's optical though, make sure that your scan rails are properly lubricated. A dry rail can cause the light source to tip, changing image focus, and perhaps exposing a fleck of dust it wouldn't ordinarily see. =^..^=
      • epintotox
        the noob one
        • Mar 2015
        • 14
        hi all
        try scan to pc using adf and platen glass. see got line or not. if still got, try copy using platen glass, see the light is on or not during copy.
        • allan
          RTFM!!
          • 5462
          Scan something white that is bigger than the platen glass. like BC said the fact that it tapers is weird. That then could mean that there is light shining in there. Turn your entire machine by 90 degrees and make a copy.
          Whatever
          • imihm
            • Feb 2014
            • 77
            hi all
            Hi there.
            Check debris or spot on the exposure lamp.
            • emujo
              • Jun 2009
              • 3009
              not sure how rotating MFP helps, but hey, maybe KM needs to put this step in the trouble shooting guide...Emujo
              • darry1322
                • Oct 2010
                • 817
                Originally posted by emujo
                [/B]
                allan was referring to the possibility of a light source shining into the optics. Turning the machine can block that external source.
                • emujo
                  • Jun 2009
                  • 3009
                  OK, now I can see how that might help...We usually just run the non image area erase test, if it fails then we might suspect a extraneous light source. Emujo
                  • jakani
                    • Dec 2014
                    • 147
                    hi all
                    thanks for your suggestions ,
                    when i went to try out these solutions , i found that the problem vanished without doing anything
                    the suggestions where great and useful
                      • 23010
                      hi all
                      ... and unnecessary. Hopefully it won't bounce back right away. =^..^=
                      • Iowatech
                        Not a service manager
                        • 3930
                        Fair warning - the last Konica equipment I worked on was analog, so what follows might be nonsense.
                        Still, if that machine has a CCD and moving carriages in the scanner, that line most likely was caused by dust on the mirrors under the platen glass. As the scanning carriages distance from the CCD changes, so does the width of the shadow from the dust on the mirror change on the CCD.
                        It might not hurt to have someone who knows what they are doing clean the inside of the scanner. Usually, the parts underneath the platen glass are pretty fragile.
                        Sorry if that was a waste of time.
