Bizhub fax issue
  • christian09
    • Sep 2014
    • 9
    Bizhub fax issue
    Interesting problem...bizhub223...everything great except fax Rx's only receive 1page of multiple page faxes,from multiple numbers, and tested ricogfax just fine.
  • copydocinc
    • Mar 2015
    • 263
    Re: Bizhub fax issue
    Unplug power cord, after turning machine off. Plug back in, try again. I know this is elementary, but the best of us have forgotten to do the basics form time to time
    • christian09
      • Sep 2014
      • 9
      Thanks doc. Already tried it.
      • allan
        RTFM!!
        • 5462
        Do you think its a bad line?
        Or that fax configuration is wrong.
        Whatever
        • copier tech
          • 8144
          I agree this is most likely a bad line, plug in a handset & make a call, listen for crackles etc
          • christian09
            • Sep 2014
            • 9
            Thank you for helping. Dumb question, but how do we test for a bad line?
            I have a hard time overcoming a customer that says "why is it working on my Ricoh fax?"
            • allan
              RTFM!!
              • 5462
              You can connect a handset and listen for crackling sounds and any abnormality.
              Is the machine connected to PSTN or PABX?
              Whatever
              • allan
                RTFM!!
                • 5462
                Sorry missed you post there
                Ok go to the job log and get the code that pops up there under detail. that could help, does the machine give a failure message or a NG delivery report.
                Did you check the marketing area?
                Did you reinitialize the fax?
                What have you tried so far?
                Whatever
                • christian09
                  • Sep 2014
                  • 9
                  Hi there.
                  Checked the line....clear
                  Set for pb.
                  Tried: ecm off,slowed to9600,reinitialize fax,next step is new fax board.
                  It s quite odd, sometimes it prints 1 page of a multipage, other times nothing. Yesterday I sent 3 pages OK, then nothing...no real pattern. When you mention marketing area, I recall like a353 set to Japanese. And it caused odd fax issues. Will check this.
                  Thanks again.
                  • Iowatech
                    Not a service manager
                    • 3930
                    For what it is worth, it appears that there are a lot of people with Bizhub experience here:
                    http://www.copytechnet.com/forums/konica-minolta/
                    You might try posting there too.
                    • RRodgers
                      • Jun 2009
                      • 1947
                      As mentioned, take it out of JP mode
                      (happens all the time)
