Yellow imaging problems
  • Richards
    • Feb 2015
    • 19
    I have a Konica Monolta c450. The yellow is not laying down very well. When I clean the IU it works better for only a few copies. Is this the IU unit htat is the problem or could it be the transfer belt? (all other colors appear just fine)
  • Albonline
    • Sep 2008
    • 1153
    Re: Yellow imaging problems
    is there iron in the cleaner box? if so hv unit and toner hopper mod. if this i not enough info, get a copier tech to look at it.
    • Richards
      • Feb 2015
      • 19
      Thanks, I will check into that. I have not broken the IU unit down yet - too new at this.
      Would love to get a copier rep, but the only ones I know of around here would simply start changing parts and I am trying to cut down on my costs.
      • allan
        RTFM!!
        • 5462
        If all the other colors are OK and there are not mixed color dirty lines, then its safe to assume the transfer belt is OK.
        Whatever
