Konica Minolta C451 card stock jams in printer
  • KonicaMinolta451user
    • Mar 2015
    • 17
    Please Help!! I have a KM C451 that had an issue with card stock jamming in the bypass tray. When the paper would finally feed through after jamming 10 times it would print normally. I cleaned the feed rollers and now the jamming issue has been eliminated. But now something else is occurring! When the paper goes through the bypass tray it jams in the printer and I have to open the fuser door to extract the paper. I have attached pictures which show the issue I am having. The first picture shows how the card stock comes out of the printer after jamming. The second image shows how the image is supposed to look. The rest of the pictures show how the card stock is stuck in the machine and the error that I am getting on the display. This only occurs on card stock since I have ran glossy paper through and its works just fine. Any thoughts on what could be causing this?
    .P1010151.jpgP1010152.jpgP1010153.jpgP1010156.jpgP1010157.jpgP1010158.jpgP1010159.jpgP1010160.jpgP1010161.jpgP1010163.jpg
  • allan
    RTFM!!
    • 5459
    Re: Konica Minolta C451 card stock jams in printer
    This is a really silly question, are you changing the paper type on the panel and the printing preferences on the driver?
    Whatever
      • Mar 2015
      • 17
      Just checked it. All the preferences on the printer and in the driver are the same. All preferences are the same from yesterday, when the paper fed through okay.
      • copier tech
        • 8098
        Running a lot or card will wear out the fuser fast. What is the life of the fuser, has it been "reset"?
        Also give the reg roller and vertical path rollers good clean, might help.
          • Mar 2015
          • 17
          I will check it in the morning but I'm pretty sure it has a lot of life left. Ill take a picture of the consumable screen as well. To my knowledge the fuser hasn't been reset.
            • 14346
            He wasn't asking if the paper settings were the same. He was asking if you are changing paper settings to "Thick 4"?
              • Mar 2015
              • 17
              In the driver, the setting was on "Thick 3" but I have just changed it to "Thick 4" and I'm going to try running it through again now. . . . fingers crossed
                • Mar 2015
                • 17
                WOOOOOOOOOOOOOOHOOOOOOOOOOOOOOOOOOOOOOOOO!!! ISSUE SOLVED!!! Changed the settiing in the driver to "Thick 4" and it ran perfectly the first time with no jams (something that has never happened before!) Also noticed that the paper size was set to 11x17 in the driver and the cardstock is actually 12x18. Thank you guys for all your help I love this forum!!!!!!
