konica 361 job llist
  • DOE
    • Mar 2010
    • 258
    have a konica 361 that has lob list lit up on left side of screen. touching it doesnt turn it off and everytime you make a copy on glass you have to tell it your finished and press several buttons to make copy instead if putting copy on glass and hitting start button. how do i turn job list off. also does the 361 have auto tray switch for finisher. thanks
  • kingarthur
    • 1354
    Re: konica 361 job llist
    i would suspect the reason for you having to press various buttons to copy on the glass is because of a machine setting, go into utility, user settings, copy, and set back to factory default....if i remember correctly it's one of the sort settings,
