BizHub C280
  • aAandy
    • Apr 2012
    • 370
    [Dead] BizHub C280
    Hello everywon
    C280 powers up, can hear motors running etc as if the DC controller is doing its thang - but no display at all
    i have the HDD out & am running hitachi diag tests on it, fast test showed a pass with no errors, slow test is in progress
    having read through many threads, the only thing that came up as a possibility was bad RAM
    any pointers would be much appreciated - and if it is RAM,, what type of RAM do i need for it? (the machine is a 1 hour drive away, so i'd prefer not to return to remove the RAM etc)
    thanks in advance
    Andy
  • aAandy
    • Apr 2012
    • 370
    Re: BizHub C280
    bump
    anybody????
    • allan
      RTFM!!
      • 5462
      Re: BizHub C280
      does the machine stabilize if you open and close the front door. Maybe its a bad panel.
      but in the both cases i had something similar the MFPB's was bad.
      Whatever
      • rrrohan
        • Sep 2011
        • 1977
        Re: BizHub C280
        Pc2-4300 2gb
        • aAandy
          • Apr 2012
          • 370
          Re: BizHub C280
          got myself a used MFP board from a working machine, with ram & a battery memory module
          before i go install it, is there anything else i should know? is there any chance the dead MFP board has damaged the DC controller? should i test it without the fax board fitted just in case that got taken out by the MFP board?
          any further tips would be very much appreciated
          thanks again
          Andy
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            Re: BizHub C280
            thanks again
            Andy
            "battery memory module" is the NVRAM, use the one that originally came with the machine.
            Here in konica town, we don't use canon terminology like "DC controller", we call it a printer control board. You may get more attention using the correct terminology
            You can install the second hand mfp board without issue, if you start it up without the fax card installed you will just get an error. no big deal, atleast you will know if it is alive or not.
            Every time ive had a 360 series do this its been the mfp board.
            Update the firmware when your done too.
            • aAandy
              • Apr 2012
              • 370
              Re: BizHub C280
              how can i be sure the NVRAM didn't get killed by the MFP board? i'd prefer to reprogram everything rather than fit the old NVRAM & find it kills the replacement MFP board
              it was 22 yrs ago i worked for Konica Australia, excuse me for using the generic term for the board
              thanks for the tips
              • fixthecopier
                ALIEN OVERLORD
                • 4713
                Re: BizHub C280
                I would agree with the other post. If I am working on a Konica and it boots without a screen, I am looking at the MFB. Never heard of an issue where it damaged the nvram, or the other way around. Usually one or the other is bad. And while you are swapping company terms, the MFB on a Konica is the formatter on an HP.
                • allan
                  RTFM!!
                  • 5462
                  Re: BizHub C280
                  Yes aslo no problem with using existing NVRam, but you will get a license management error that can only be cleared with the LMS server.
                  The error does not affect the operation of the machine.
                  Whatever
                  • aAandy
                    • Apr 2012
                    • 370
                    Re: BizHub C280
                    thank you one and all for your time, effort & advice - it is very much appreciated
                    • aAandy
                      • Apr 2012
                      • 370
                      Re: BizHub C280
                      not so good news
                      installed replacement MFP board, used original HDD & NVRAM - machine fires up & gives me a C-C164 error (ROM contents error) - does this mean my 2nd hand board supplier didn't give me a board from a C280?
                      I presume this means I need to update firmware, but I've no access to firmware & I've not done a firmware update on these machines before
                      any further direction would be greatly appreciated
                      Andy
