SD-506 on a C6501 intermittent jamming J-7568 but strange workaround helps...
  • methogod
    • Dec 2008
    • 922
    [Jamming] SD-506 on a C6501 intermittent jamming J-7568 but strange workaround helps...
    Happens with both 8.5x11, 9x12 and larger sheets (12x18) - seems I can get 20-50 booklets out then it starts to happen. I then can stop it by telling the RU to de-curl DOWN. this will stop the jamming, i still get some malformed booklets but i suspect that is the wear on my fold rollers which do need replacement.
    Its almost like the drive that pushes the collated sheets around the right angle is not working correctly. Which i think is also why it takes longer to start to happen with larger sheets, this tends to happen more with coated paper vs uncoated.
    When i have larger runs i try to only use uncoated sheets, but still see the same issue.
    I dont have access to MKM can anyone search code for solutions...
    Anyone seen this before?
    Anyone fixed this before?
    thanks for the help as always...
  • rob
    • Oct 2014
    • 2
    Re: SD-506 on a C6501 intermittent jamming J-7568 but strange workaround helps...
    Hi I have the same problem myself, Jammin in the same spot, If i send though say 5 pages 3 of them go though and the last 2 stay in the Hoz stacker. will get back to you with the fix when I find one.
    • Mick01
      • Nov 2012
      • 362
      Hi,
      Had a phone call about this very issue this morning.
      It turned out to be that SD6 (roller release solenoid/2) was sticking down. The solenoid was not releasing the rollers so the paper was crashing as it was doing the right angle turn before sending the paper to be folded.
      Hope this helps.
        • 23010
        The two SD-510's that I care for seem to be most affected by the way the paper is loaded. My customer does tons of LTR-R booklets, Which will jam every 5 or 6 booklets if the paper guides are loose by 5mm. Snug up the guides and you can run booklets all day without a jam.
        The guides won't stay tight? Replace the rod that the guides clamp to. You'll find deep cuts in the rod. =^..^=
        • rob
          • Oct 2014
          • 2
          Thanks for that info guys, I found a firmware upgrade that has seamed to have fixed the problem for now. will let you know
          • JAkelar
            • Mar 2018
            • 18
            so i had a similiar issue on the sd506 where it was jamming at the lifter before the 90 degree. and it was because one of the magnet screws was loose.
            now though im having the issue where it jams there and it seems like its because the lifter isnt raising up to where the paper will be.
