Konica 501 import address book
  • Lasersupplies
    • Jul 2011
    • 221
    Hi guys,
    Im trying to import an address book from one Konica 501 to another Konica 501 and upon import i receive the following import error.
    "File Format Error (symbols/characters that cannot be used are used in destinations/names, etc.)"
    Is there anything that needs modified in this file?
    Thanks in advance
  • Imsdal
    • Aug 2009
    • 111
    Re: Konica 501 import address book
    Check the Version on both if they are the same.
    If is not just erase, change and save in the notes abbr.txt
    Imsdal
    • rrrohan
      • Sep 2011
      • 1977
      Are you using data administrator?
      • SmellsHot
        Head Tech
        • 512
        I assume he is using the import/export feature from the web interface. Pagescope data administrator is quick and easy to use if you cannot get it working via import/export
        Everyone has the right to be stupid. Some people just abuse this privelage more than others
        • Kapral
          • Oct 2012
          • 44
          Yup, I also recommend Page Scope Data Administrator. Works as charm.
