bizhub 421 regarding usb port
  • goldencup
    • Nov 2008
    • 366
    Hi,
    i would like to ask how to activate the usb port of bizhub 421. I have machine that do not have the external memory icon on the panel,but my other machine have. is there any adjustment needed to be done or parts that is needed to install on the machine?
    Thank you very much.
    Attatched is the image of the two machine the one with external memory icon and the one without.
  • allan
    RTFM!!
    • 5462
    Re: bizhub 421 regarding usb port
    Go to administrator settings -> system settings -> user box settings -> external USB memory settings.
    Change that needs to be changed there and it should work.
    Check if you have the HDD installed and set correctly.
    Whatever
    • goldencup
      • Nov 2008
      • 366
      Thank you very much for the reply sir. So i need a Hard Disk to enable the USB port?
      • allan
        RTFM!!
        • 5462
        No u need a HDD to get the user box function to be fully functional. The USB storage is seen as a type of user box.
        Whatever
          • 23009
          That sounds like a 'round-about "Yes" to me. =^..^=
          • goldencup
            • Nov 2008
            • 366
            I have already installed the HDD and plug a flash drive but the file inside the flash drive is not detected. i tried formatting it to FAT32 & NTFS also tried another flash drive. Is there any settings that i need to look or adjust?
              • 23009
              What file format? Depending on what manufacturer, what machine, you may be able to view one or more of PDF, JPG, or BMP. The only universally acceptable file format seems to be PDF. =^..^=
