Bought a used fuser about 3 months ago. Installed it. Worked great.
Last week the machine told me that the black IU, the transfer belt and the fuser needed to be replaced. This happened all at once. I expected this to happen to the IU and the transfer belt; so I replaced the IU and replaced the fuse on the transfer belt. The notices on both went off.
However, when I replaced the fuser with another used fuser which I purchased, the notice did not go off. I tried to reset it by holding the utility button down and turning the machine on. It just sits there saying that it is warming up (13 minutes) - which it is not.
I jumped the resistor on the fuser of the one that had been in there. I jumped it using a 100mA fuse in a fuse holder. No luck.
Both fusers will warm up, but the machine says to replace them. Help!! Could this be a motor/gear problem? Where would I start looking?
