Connecting a FS-534 to a konicaminolta B552
  • michael_braunstein
    • Feb 2015
    • 29
    The Konica Minolta B552 comes with two available finishers. The FS-526 and the FS-527. I'm currently trying to connect the B552 with a FS-527 finisher but seem to be missing the correct mounting brackets. I'm not a 100% sure. I think what I need is the set up instructions to connect the FS-527 to the B552. I alrteady have the instructions to connect the finisher to the C360, which is the wrong one. Any information would be appreciated. Thanks
    • 23008
    Re: Connecting a FS-534 to a konicaminolta B552
    If I remember correctly the FS-527 comes with two sets of attachment brackets. The ones for the Minolta build copiers, and the ones for the Konica build copiers. If you look in the bizhub 552 manual you should be able to find the installation instructions that will explain it all. =^..^=
    • emujo
      • Jun 2009
      • 3009
      FS-527_bizhubC452InstallInstr.pdf
      part # of attachment items. Emujo
        • Feb 2015
        • 29
        Originally posted by emujo
        [ATTACH]29248[/ATTACH]
        Thank you but, any chance that you might have all the pages to the install instructions so I can get the correct part numbers
          • 23008
          You got some of it emujo. A little toward the center ... You'll get used to that scanner eventually.
          Here is a link to the installation manual (thank you Google).
          FS527_A0HR-9550-02E.pdf - Installation Manual - ramirez_pl - http://chomikuj.pl
          The brackets you seek come attached to the base machine. You'll want items 19, 20, 22, and 26 on pg 32 of the MFP parts manual. See attachments:
