BIZHUB C450 : "Gray patch returns in the center of copy image"
  • radoratovo
    [Misc] BIZHUB C450 : "Gray patch returns in the center of copy image"
    hello every body!
    I don't know but after upgrading firmware version it worked good with copy but I can't print till PC, I try to execute NVRAM RECOVERY it's OK but my BIZHUB C450 had a problem , I can print something but with copy : Gray patch returns in the center of copy image
    what should I do?
  • darry1322
    • Oct 2010
    • 817
    Re: BIZHUB C450 : "Gray patch returns in the center of copy image"
    After NVRAM recovery you need to go through all the setup steps, in order, to completion.
