bizhub 350 light copies
  • brent
    • Nov 2008
    • 1212
    ok peeps I am drawing a blank light copies on a drum that had 50 percent left.. I did a drum unit. developer and developer unit. because it needed a dv it had like 400k and the problem persists. other then the laser unit. is there any advice on what I can check next. ? the copies are light but still readable. just am drawing a blank on this
    and thought I would ask for help thanks
    brent
    • 22999
    Re: bizhub 350 light copies
    Did you do any simulations, like a developer stir, or reset counts? =^..^=
    • brent
      • Nov 2008
      • 1212
      Sure did. Reset counters. And ran an f8
        • 22999
        Are you using OEM toner? =^..^=
        • fixthecopier
          ALIEN OVERLORD
          • 4714
          Are the internal f-12 prints also light? are you running original through adf or on glass
          • allan
            RTFM!!
            • 5462
            Check the transfer. The contacts on the door bend.
            And the developer gears break.
            Whatever
            • fixthecopier
              ALIEN OVERLORD
              • 4714
              In addition to those door contacts, you indicated you changed the dv tank for being over 400k , if you have never changed the transfer roller, now is the time.
                • 14534
                If you are using aftermarket toner, get rid of it. Since we switched back to OEM drums and toner we are getting up to and sometimes over 200% drum life. Service calls have gone way down and fusers are lasting quite a bit longer as well. The money we were saving on AM drums and toner was getting more than used up with service calls.
                One of the main problems we had while using Densi toner on the BH350 series was low image density. It would be fine after a drum and dev change but get steadily lighter as the Densi toner got mixed in.
                Just my two cents.
                • fixthecopier
                  ALIEN OVERLORD
                  • 4714
                  Ok Brent, how about a little closure on this.
                  • wseyller
                    • Sep 2012
                    • 1129
                    Not sure if I missed it but I never saw mention if this happens with prints from computer or internal. I just saw copies being mentioned. Sure its not just dirty optics in scanner. Also there is user setting of adf for light/dark copies.
                    Edit: just noticed fixthecopier asked if F12 prints are light but never got an answer to that.
                    • CraigW
                      • Dec 2010
                      • 417
                      I had a 200 once that got light everything, and ended up being the drum unit in my case. Only about 40k into life also.
