c754 jam code 32
  • Kenny
    • Jun 2009
    • 529
    c754 jam code 32
    Hi we have a few 754 with finishers , that are coming up with Jam code 32 ?
    Has anyone seen this before and any ideas how to fix it ?>
    Kenny
  • JSC
    Gimp
    • Dec 2006
    • 618
    Re: c754 jam code 32
    Kenny
    Is that with the FS535?
    The gene pool could use a little chlorine.
    • Kenny
      • Jun 2009
      • 529
      Yes a FS535
      Regards
      David
      • JSC
        Gimp
        • Dec 2006
        • 618
        Yea I have a couple that jam, show J32 on the display but the operator can't find it. On arrival paper is stuck in-between relay rollers in the finisher, but very difficult for the user to see or clear. once cleared the machine runs fine but worryingly there is no jam logged in the jam count.
        I have updated firmware, changed finisher control board all with no joy.... nothing known about it by Konica Minolta as yet..
        Net time I get one im taking pictures, and printing off data sheets to send off to Konica Minolta.
        • Kenny
          • Jun 2009
          • 529
          Thanks JSC
          Exactly as you described ! If you could let me know your findings id be most grateful, I will do the same !
          Kind regards
          Kenny
          • JSC
            Gimp
            • Dec 2006
            • 618
            Thanks JSC
            Kind regards
            Kenny
            Will do.
            Good luck out there!
            • Kenny
              • Jun 2009
              • 529
              you too buddy
              • Kenny
                • Jun 2009
                • 529
                Anyone else experienced this ?
                • hotfuser
                  • 180
                  if this is the jam in where the paper gets stuck in the finisher there is a modified shaft that is longer with a turning knob on the end.
                  I have enclosed the bulletins.
                  • srslyartyg
                    • Nov 2014
                    • 9
                    This sounds exactly like what I need to fix a few machines that are repeat offenders. Thanks for the info, guys!
                    Has anyone completed the install with the revised bulletin/parts?
