C224e paper jam 3003
  • jonbonse
    • Jun 2009
    • 737
    #16
    Re: C224e paper jam 3003
    Those in cassette 3 paper feed unit. Just swap them with another from working tray and test if don't have spare ones.
    The cassette rollers are brand new
    • tsbservice
      Field tech
      • 8064
      #17
      He Albonline means one-ways...me too
      • jonbonse
        • Jun 2009
        • 737
        #18
        Do you mean the black transport rollers seen when opening the right door?
        • Synthohol
          Certified Konica Expert
          • 5908
          #19
          no, the black one way bearings that touch and turn the rollers on the shaft, they slide off for cleaning with IPA.
          dont forget to scuff the shafts where the needle bearings ride and clean with IPA..
          • jonbonse
            • Jun 2009
            • 737
            #20
            Thank you!
            I suspected he might have meant the one way clutches not rollers...
            No that's one thing i didn't check bit will be going back so will swap round and see...
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
              #21
              something else to keep in mind with these C224 - C368 fusing units is that the black non stick film on the fusing entrance plate likes to crack and peal in the centre and cause fusing entrance jams.
              You do not have to replace the fusing unit.
              I disassemble it, remove the plate and slice off the offending section.
              On one machine in the middle of the covid crisis where no fusers were available and i screwed it up - I removed the entire film and cleaned all the glue off. It's still working fine 3 months later.
              Always seems to happen at the 300k mark on low volume machines (the factory fitted fuser, 4, 4e and 8 series have seen it)
