C224e Rare rectangular voids in scan files (compact PDF)
  • giddyupngo
    • Oct 2014
    • 109
    Hi everyone, thanks for reading.
    2-3 times per month, customer is getting a single rectangular void area on a scan file, 1 inch by 3.5 inches. They are scanning legal documents through the ADF. They have never seen the void on prints or copies. Upgrading firmware from G9 to K2.
    Has anyone ever seen this? Cannot scan in a sample due to confidentiality. I only have one sample.
    • 23010
    Re: C224e Rare rectangular voids in scan files (compact PDF)
    Are they prohibited originals? Birth certificates, stock certificates, currency, etc., etc.
    • giddyupngo
      • Oct 2014
      • 109
      Good question,
      The original I saw was a database record, so basically fields of text without outlined cells with some handwriting too. If the machine thought it was a prohibited original, would that trigger a code internally? Would it actually remove a section of the image?
        • 23010
        Originally posted by giddyupngo
        ... If the machine thought it was a prohibited original, would that trigger a code internally? Would it actually remove a section of the image?
        I don't know the answer to that question. Typically Kyocera will produce a blank image and store an error code. Toshiba will just error out. I don't know about Konica Minolta. It's never come up. =^..^=
        • giddyupngo
          • Oct 2014
          • 109
          Thanks Black Cat,
          I opened a ticket with Konica Minolta, this is their recommendation.
          If the K2 firmware does not solve it, next 2 steps are:
          replace MFPB Dimm
          replace MFPB
          The technician from K.M. didn't think an image would be partially erased, he thought it would be all black on printout, all or nothing in other words.
          • fixthecopier
            ALIEN OVERLORD
            • 4713
            last time I saw someone trying to copy something they shouldn't on a newer bizhub, it just made the quality really crappy.
              • 23010
              Please keep up posted on your progress. =^..^=
              • giddyupngo
                • Oct 2014
                • 109
                Hello,
                Haven't heard of any more problems since upgrading the firmware to K2. That must have done it.
                • Bob Wescott
                  • Sep 2013
                  • 14
                  When you say "compact PDF" my first thought is memory. Try scanning not in compact mode.
                  • giddyupngo
                    • Oct 2014
                    • 109
                    Good suggestion Bob, I will keep that in mind if they call back.
