bizhub 654e with intermittent C9401
    • 22997
    I've got a long list of possibilities, and I'm ranking them like this:
    1) CCDB: 40%
    2) Flat Cable: 20%
    3) SCDB: 20%
    4) Inverter: 10%
    5) Lamp: 5%
    6) something else: 4%
    7) MFPB: 1/2%
    8) firmware: 1/2%
    The threads seem to be leaning towards the CCDB. It clears, but returns within a week.
    I've got a very attentive keyop so if there were any quality samples to be had, I would have them. The lamp consistently lights, nice and brightly. I've done all the free and easy stuff: Firmware, and reseating connectors all the way back to the MFPB.
    Have I missed anything? How about the rankings? =^..^=
  • splblazer91
    • Jul 2014
    • 204
    Re: bizhub 654e with intermittent C9401
    So far all the ones Ive fixed (8) have been CCD replacement and latest firmware combo. Make sure you do them together or you could get a different error code for a CCD Mismatch. Unfortunately KM is not replacing these free of charge either. Costing us a fortune.
      • 22997
      Thanks splblazer. Just to clarify, are you recommending that I re-load the firmware following the CCD replacement? It's already current at K2. =^..^=
      • splblazer91
        • Jul 2014
        • 204
        If you are at K2 then you should be fine.
        • Laserbeam
          • Aug 2011
          • 152
          Hello,
          I have the same problem with 654e, 2-3 times a week code C-9401 appears. First I replaced the ADF-cable with a modified one (pn A3CEN11711) but unfortunatelly without success. Could it be the CIS ??? Or should I now replace the CCD?
          Or there are new findings in the meantime?
          • habik
            • 2013
            Originally posted by Laserbeam
            Hello,
            What firmware are you on at this moment?
            Firmwares HERE
              • 22997
              Hello,
              The C9401 is usually caused by the CCDB + firmware.
              The C9402 is usually caused by the CIS senor harness.
              What code are you getting? =^..^=
              • Laserbeam
                • Aug 2011
                • 152
                @ blackcat4866
                I get the code C-9401
                @ habik
                Firmware Ver. G20-M0
