I think I have done this swap before, but can't remember for sure. I have a 200 with a printhead that is screaming, and my only BZ parts machine with a head still in it is a 350. I don't want to go through the pain of calling tech support to ask and don't want to instal it and it not work. Thanks.
Does a BZ 350 printhead work on a BZ 200?
The greatest enemy of knowledge isn't ignorance, it is the illusion of knowledge. Stephen HawkingTags: None -
Re: Does a BZ 350 printhead work on a BZ 200?
but i would give it a go as the faster PH may work in a slower machine and not vice versa. -
The greatest enemy of knowledge isn't ignorance, it is the illusion of knowledge. Stephen HawkingComment
Yep,it worked fine.The greatest enemy of knowledge isn't ignorance, it is the illusion of knowledge. Stephen HawkingComment
jerogers2004
The Bizhub 350's print head is different than the one used in the Bizhub 250/200
Part Numbers
4040075100 P/H ASSY Bizhub 350
4041075100 P/H ASSY Bizhub 250/200Comment
If the Polygon Mirror is noisy, just replace the rotating mirror from any BH-200,250,350 machine. They are all the same. Only the electronics are different. No need for the whole unit. Most of the time the mirrors loose the counterbalance weights which are blobs of glue.
Hans“Sent from my Intel 80286 using MS-DOS 2.0”
