Does a BZ 350 printhead work on a BZ 200?
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    I think I have done this swap before, but can't remember for sure. I have a 200 with a printhead that is screaming, and my only BZ parts machine with a head still in it is a 350. I don't want to go through the pain of calling tech support to ask and don't want to instal it and it not work. Thanks.
  • hotfuser
    • 180
    Re: Does a BZ 350 printhead work on a BZ 200?
    i dont think the 350 fits as the 250 and 200 are the same.
    but i would give it a go as the faster PH may work in a slower machine and not vice versa.
    • fixthecopier
      ALIEN OVERLORD
      • 4713
      That's exactly what I as thinking.
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        Yep,it worked fine.
        • jerogers2004
          The Bizhub 350's print head is different than the one used in the Bizhub 250/200
          Part Numbers
          4040075100 P/H ASSY Bizhub 350
          4041075100 P/H ASSY Bizhub 250/200
          • Hansoon
            • Sep 2007
            • 3384
            If the Polygon Mirror is noisy, just replace the rotating mirror from any BH-200,250,350 machine. They are all the same. Only the electronics are different. No need for the whole unit. Most of the time the mirrors loose the counterbalance weights which are blobs of glue.
            Hans
