Bizhub C450, computers unable to find printer after network upgrade (ws2012R2)
  • AJ058
    • Feb 2010
    • 24
    Bizhub C450, (no fiery connected)computers unable to find printer after network upgrade (ws2012R2)
    Even searching using IP and MAC addresses.
    Even connecting directly to a win 7 computer acts like it is finding but print test fails
    Ping IP, no connection.
    NIC lights blink, I replaced network cable no help
    We had also upgraded the wireless router, so removed, reinstalled old router, no help
    Computers can print to other printers, can see and open files on server,
    So apparently a setting is wrong in the Bizhub C450.(unless the NIC suddenly failed)
    Another tech (no KM C450experience) had looked at the C450, to evaluate,
    to see if he would be any help to re-deploy the network
    I do not believe he changed anything, but may have without being aware he did.
    I haven't been able to figure out the change, what is turned off/on that should be
    so probably need to re-start setup. Any pointers would be wonderful
    Old system, was Win Server 2008R2 sp1 using workgroups (re-connected but still no connection).
    6 workstations, I-pad, 3 laptops all setup to allow direct printing
    the NEW win server 2012R2 almost requires that you use a domain.
    We started to set up domain, but when printer would not connect, we decided to go back to a workgroup
    so we removed the domain and set up using a workgroup similar to prior server.
    was connecting and printing prior to server upgrade, was not connecting before or after domain removal
    Has Anyone set up a bizhub C450 or similar on a Win Server 2012R2 network?
    or have a cheat sheet on what settings should be on the Bizhub c450 admin panel to confirm settings/values?
    Or a quick, step by step, setup guide to connect to router or server.
  • hotfuser
    • 180
    Re: Bizhub C450, computers unable to find printer after network upgrade (ws2012R2)
    not trying to teach you how to suck eggs but have you tried just connecting a laptop directly to the copier just to eliminate their network?.
    • AJ058
      • Feb 2010
      • 24
      Thanks for the reply, They actually print through the wireless router and upload/download files to/from server and occasionally other workstations.
      • copytechman
        • Nov 2008
        • 943
        Not to duplicate posts but again, laptop and crossover cable?
        Regards!
        A.
        • darry1322
          • Oct 2010
          • 817
          If you can print with a cable directly into the copier from a laptop, then the copier NIC is OK. This is a troubleshooting step you can use to narrow down the problem. Give it a try.
          • nmfaxman
            • 1702
            Make sure it has a static IP address that is not in the scope of the dhcp server.
            I put the machine to dhcp and then add 100 to the last octet for the IP address.
            You will need to do it when you hook up with a crossover cable and laptop.
            He is an IT guy, he has a laptop on site.
            • AJ058
              • Feb 2010
              • 24
              That was the third thing I tried.
              But I did figure out the problem--s. Somehow the tech I believe defaulted the C450 back to factory settings as two things were changed. Like I suspected, the problem was with the printer setup.
              1.Printer was looking for the fiery, which it came with, but had been disconnected.
              2. and the IP was changed to 192.168.0.*** rather than 192.168.1.*** which I did not notice being so close,
              the prior may have been the fiery IP setting causing it did not ping the IP. as soon as I changed back, all computers can now print.
              Hope this helps someone else.
              • darry1322
                • Oct 2010
                • 817
                I saw where you said you tried printing directly from a Win 7 machine, but didn't know if that was a direct cable connection or just printing from a local TCP/IP port instead of printing through the server.
                Glad you got the problem resolved.
