Minolta c253 on colour mode black and white prints
  • copytrust
    • Feb 2010
    • 118
    Hello guys i have a client with a Minolta c253 sometimes his machines prints black and white on colour mode!
    1/20 there is a black print, and sometimes 2/20, this is something never seen before, any clues??
  • Hansoon
    • Sep 2007
    • 3385
    Re: Minolta c253 on colour mode black and white prints
    I had (have?) one doing this. Changing the transfer belt cured it for the moment. No service codes however when it happened so I am still not really sure if the problem lays in the TB or machine itself. Machine is working now since 3 weeks after I changed the transfer belt.
    Hans
    • copytrust
      • Feb 2010
      • 118
      Thank you for the repply i will try a transfer belt, i have to say it is a very odd problem, i was thinking network-software.
      • copytrust
        • Feb 2010
        • 118
        Hansoon
        Hans
        After replacing the transfer belt and testing the machine it seems everything is ok, thank you very much for your reply.
        • Hansoon
          • Sep 2007
          • 3385
          Thanks for the feed back. I sincerely hope for both of us that its indeed the TB. Still I'm not very convinced that the problem lays only within the TB itself cause I cannot technically explain the phenomena.
          Hans
          • srslyartyg
            • Nov 2014
            • 9
            Check the Printer Driver settings. I've seen this before. Make sure it's not the monochrome driver for some reason and make sure it's not defaulted to override the color option.
            Good luck.
            • Cookr
              • Dec 2011
              • 184
              http://www.copytechnet.com/forums/ko...-no-color.html
              Might help I had same Problem on a c203. Customer ended up upgrading anyway but my problem was the transfer rollers were not dropping on CMY.
              • Hansoon
                • Sep 2007
                • 3385
                • AjitN
                  • Mar 2009
                  • 287
                  I would like to have some more inf. about problem.
                  When 1/20 or 2/20 prints in black means what ever color in CMY does not get printed and where ever there is black in the file that gets printed OR all CMY area gets converted in to black.
                  In first case it could be 1st transfer roller retract problem as the clutch is sluggish and it is not holding transfer rolls on drum unit firmly.
                  In second case check the job and driver settings, in the same job if few pages have very few % of color mixed with black, try full color and put off pure black as machine will treat that as black page.
                  Last I think of upgrading OR loading firmware.
                  Hope this helps
                  • copier tech
                    • 8144
                    I had this exact same problem, all I did was clean the ID patch sensors & problem never came back. This will also explain your P-codes
                    • artsani_it
                      • Jun 2017
                      • 2
                      hello. we have the exact same problem. could you tell us where are those ID patch sensors located? thank you!
                      • copier tech
                        • 8144
                        Have a a read of the service manual (link below)
                        http://www.arbikas.com/view/locator/..._c353_A02E.pdf
                        • artsani_it
                          • Jun 2017
                          • 2
                          thank you. i wasn't able to find in the service manual, no info about those sensors. could you be more specific, please?
                          • copier tech
                            • 8144
                            This this service manual, page 43.
                            www.https://mega.nz/#!tYMQ3bzI!GKB9JWxgh...OWg49tw7qzD9wY
