C1105 on a C654e with FS535
  • big jase
    • Jul 2008
    • 136
    [Error Code] C1105 on a C654e with FS535
    Has any one had this fault? can't clear error i have swap motor (m6) no joy
    If at First you don't succeed remove all evidence of ever trying!
  • splblazer91
    • Jul 2014
    • 204
    Re: C1105 on a C654e with FS535
    is this happening while using 3 hole punch paper?
    • big jase
      • Jul 2008
      • 136
      No every copy/print
      • big jase
        • Jul 2008
        • 136
        Solved the Pin had split in the drive gear see attached pic gear 15 pin k
        • splblazer91
          • Jul 2014
          • 204
          The actual pin broke or the slot in the gear where the pin goes?
          • big jase
            • Jul 2008
            • 136
            The actual pin. It the hollow type. Replaced with a solid one
            • Brett GS
              • Jun 2013
              • 154
              Thank you,going to assist one of my techs tomorow so this will be the first thing i check.
              • Woxner
                • Jul 2011
                • 853
                also check the ejector unit. i had this two days ago. the claws come off and jam it uo
